sona
- July 6, 2011
- Birmingham,AL
- 2006 Eddie Bauer
Hey guys, I just got a set of BFG KO All Terrains on my 2006 Explorer. I'm extremely happy with the look and fitment. They do rub at full lock on the fender liners, but I'm going to re-drill the holes and pin them back a little bit to correct that.
The issue I do have with the new tires is the MPG. If I keep it at 60 (65 with normal tires) I can get around 21 MPG on the HWY. But If I do anything above that, I go down to 16-18. Which is damn unacceptable. I called an off road shop to see what I could do about it, and they recommended a tune. They charge $330 for it. It essentially corrects the new tire size in the ECU and changes all of the shift points, corrects the off-kilter speedometer.
I was wondering if anyone on here has done this with any luck? I can see it fixing the speedometer, but I don't know what to expect for gas mileage improvements.
I really want to weight out my options because if this MPG is what I'm stuck with, I will have to sell the tires.
Also, does anyone know if I could benefit from re-gearing? Everything is stock except the tires.
4.0 V6
4.0 V6
