Monster Rain
- January 18, 2011
- NEPA
- '98 Explorer Sport
Thanks a lot, man. I'll check it out first thing tomorrow.
My wife is very happy, which means I am very happy!![]()
I have a 2000 Exp. 2wd. V6 4.0L. Was not getting any air from blower motor. I changed the blower motor...blower motor now works great. I put it all back together no I am only getting air from the defrost vents and no other vents. Any ideas why just changing out the blower motor would cause this or what the cure might be?
Thanks.
what is that black line called, because mine basically baked and cracked. I also am having problems with my a/c switching from front vents to defrost when acclerating.You'll notice a grey plastic line at this point-it goes to the "coolant bypass valve"
Vacuum is applied at most times, unless ac is selected
at this time the vacuum is switched off to the valve,which in turn cuts flow of coolant through the heater core. This helps the HVAC box run a bit cooler for maximun a/c efficiency
This may develop a vacuum leak-check it
BTW , this is not my truck
Now, going on through the firewall is the "reserve" or " boosted" vaccum.It is the black line.
It arrives through this connector-right above the "fuel pump inertia switch"
The white line is the controlled vacuum return-we'll discuss it later
OMG thanks guys. I havn't looked yet, but based off what you are saying and the past problems with vacuum, this has got to be it. (shwetty ball is probably retaining water)
We had run into an issue where the front lockouts would not kick in because of lack of vacuum, personally I removed the metal clips from the back of the 4x4 lock outs making it a live axle setup and its worked great.
So, being I know there is a lack of vacuum already, and I only get defrosters, now I know what to look for.
Can't thank you enough for giving me some things to check on without spending an arm and a leg at a dealership! I'll let everyone know if/what I can find over the weekend.
