WarGhost
- May 17, 2001
- WarHick, NY
- 00 Sport
Hey everyone,
I just have 3 questions. First one is what is the octane I should be using with my Diablo chip? I've run 93 and 94. It may be my imagination but my X seems to run better on 94. The next on is about the KKM filter. Is it a common thing for the X to be more temperature sensitive with the filter on? With the wacky weather going on in NY it seems that 56-65 degrees is the optimum temp. If it's too cold, the truck seems sluggish and doesn't like to shift as easily as it does when the temp is a bit warmer. If it's 75+ degrees the truck seems sluggish also but will shift easier.
And now the final question is where can I get the Volant Kit for the 4.0 V6 SOHC? Do they make and where can I get it?
Thank you!
Thank you!
