BillVT
- September 2, 2008
- Essex, VT
- `99 XLT; `02 XLT
Just put 31/10.50 -15 Dayton Timberline AT tires on my stock `99 XLT, using the stock chrome wheels. Fits fine with just a little rubbing under full steering lock on the plastic front valence. Easily fixed with a little belt sanding work, trimming back about 3/4" on the inside edge. Chose these tires because of price as the vehicle will be driven at low highway speeds and off-road on sand so I don't need an expensive tire or one that will last for many thousand miles.
Ride is fine, but the increased diameter (about 5% larger than stock 235/75-15s) does make the car work a little harder. Mileage actually dropped slightly, even correcting for diameter and odometer change.
But, these will primarily be used on beach sand (aired down to 15psi or so) and the on-road speeds will be no more than 45 MPH.
If considering a beach/sand tire, I would say go for the 31/10.50's. If you are spending a lot more time on the road or hilly terrain, then 30/9.50-15s are probably a better bet.
