- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
No, those are the higher pressure PR valves I said to avoid. The 2nd one is just an oversized version, notice the part number ending O/S?
The one I meant is this;
It's to raise the pressure by way of the boost valve circuit. That is a better way to do it, but it's not compatible with their older higher pressure PR kits, which come in the ZIP kit. They sell a simple quality replacement PR valve, that's the one to get to use with the above LB1 boost kit. Be sure you choose the parts for your model 4R, pre-98 or 98 up models.
4R70W-LB1 - Ford AODE 4R70W 4R75E 4R75W Transmission Line Pressure Booster Kit
Ford AODE 4R70W 4R75E 4R75W Transmission Line Pressure Booster Kit 4R70W-LB1 Part No. 4R70W-LB1 Unique Forward & Reverse Boost Assembly Pressure Regulator Spring Line rise control in the AODE/4R70W is different than in most units. Forward pressure is controlled by EPC oil reacting directly...
transpartswarehouse.com
