Sealing washer
Anyone who has a leaking chain tensioner needs to consider the following fix if you have exhausted all other options other than pulling and replacing the head.
See link below.
McMaster-Carr
We tried everything.
New crush washer, no crush washer, second $10 crush washer, Brass washer that comes with the SOHC timing chain tool kit, Gasket maker Black, Gasket maker Red (from the dealer), JB Weld, more JB Weld, buffed mating surface with die grinder and buffing pad, new tensioner, double crush washer.
$3.60 sealing washer from McMaster Carr and thread lock-tight, DONE! ZERO LEAKS!
Yes the washer is thicker than the crush washer but the tensioner seems to be working great. No chain rattle at all.
Good luck.
