steadyhand
- May 5, 2010
- Missouri
- 99 Mercury Mountaineer
I found a chain wrench online at Northern Tool Supply for $65 but couldn't tell if it was suitable. Where did you purchase yours? Let me know if it works.
You can use the stud bolts from your A/C compressor to pull the balancer. They are long enough and the correct thread. Just be careful that you don't break them by tightening the puller center bolt too much. Use the hammer and tap the center puller bolt head to jar the balancer loose. Tighten, tap, tighten, tap, etc.
The only bolts I see in the A/C compressor are behind the pully and can't be removed without taking the pully off. Btw, should there be only two bolts to remove the HB? I see three holes, but only two are threaded. Their located across from each other, on both sides of the HB.
I purchased the chain wrench at tool a rama.
