Can the 1st gen 4.0 top 300 hp? Curious what this motor can do, Ive been told there is just no hope for this that its as good as it gets from the factory.
There's not a lot you can do to get above the factory 160hp. You can spend a LOT of money trying, but your best bet is to just make sure everything is operating properly on your stock engine and stay that route. If you want more hp, you're looking at a motor swap. The 5.0 will work in a 1st Gen with the least amount of modification, and anything that'll work on a 5.0 Mustang motor will work on a 5.0 in an explorer!
Check the "One Mean 4.0" thread stickied at the top of this section.
There's very limited aftermarket support for these motors. If you went full out with a supercharger, port and polished heads, custom tune, cam etc. you might get close. But you're going to spend a lot. And who knows how reliable it'll be at the end of the day.
A 5.0 swap is probably less money and more reliable at the end of the day
Starters,300hp at crank or to the ground?? Big big difference, especially if auto and 4x4..auto and 4x4 will eat 20%ish of that 160 hp from factory. .also the explorer is a big HEAVY truck not made to be a big hp race car..200 Rwhp is pretty easy to get (to ground) any more and your gonna be dropping ALOT of money into it..
But remember hp isnt what these motor are know for,its TQ and thats what moves you..
A fyi my current motor makes around 300 rwhp on boost alone which dont sound like much but im beating corvettes and hanging with Vipers...just an example that it's not all about horsepower
Should've done some research first and could have done a cam and 95tm or 98 tm heads..those heads would have increased compression to 10:1
I agree with the others asking about tires and gears..you may have POS gears..explorers really need ATLEAST 3.73 or 4.10 gears to get up and move outa its own way..check you door tag or rear end tag and let us know what it is..
really all there is to do is super high compression pistons, cam, injectors, modded heads,and bullet proofing the engine so you can turbo it. it would still be able to daily well with the turbo rather than a super charger. all this may sound out of budget but you can get some good deals out there and a ebay turbo kit for around 600$ will do the trick really well pushing upwards of 15 pounds if the motor will handle it. now a 5.0 swap is the way to go for maximum power but the high horse v6 sounds like more fun to me and probably gonna happen to my build. but that's my 2 cents i enjoyed reading the thread.
I had that same problem when I changed heads on my 87 2.9L ranger. Turned out to be a valve spring retainer wasn't installed correctly. One day it would run fine, the next day it had no power. An intake valve wasn't closing all the way so it was sucking oil up into the intake. I was getting 28 mpg on the highway though.
