4r/5r bellhousing interchangability | Ford Explorer Forums
SpitfireEMT
Henderson, KY
'00 Ranger XLT
I have a 5r55e from my ranger that I want to mate to a 4.0 ohv from a 96 expo sport. Aside from one bolt hole on the engine side of the bellhousing, what other differences are there between the bellhousings? Can I simply bolt up my 5r up to the 96 engine and off I go? or do I need to change or modify the housing to make it work?
EDIT -- copied from another thread I posted in a few days ago
There's a few arguments back and fourth about that very question. You might need to go to TheRangerStation.com to find the exact answer.
But basically yes the swap from a 4r55e to the 5r55e is possible. You won't however have 5 speeds if you left your current PCM in the truck. The 5th gear in the 5r55e, -2nd to be exact-, is achieved by the PCM telling the O/D band to 'split' the 1-2 shift, essentially adding a gear between the two. I won't be able to explain that to you as I don't exactly know how it works, but that's how it's been explained to me. I think alls you'd need to do is swap the neutral safety switch from the 4r over to the 5r. If you use your stock PCM the 5r's VSS won't be used, and you just would need to plug that hole.
If you wanted the 5speed to be a 5speed you'd have to swap PCM's and a section of the wiring harness that goes back to the trans. Don't quote me but I think you'd also need to use the VSS on the tranny, instead of on the rear diff. ((or it's the other way around, I'm tired... I think our 4r's are on the rear diff.))
Here's a link to a successful swap:
http://www.therangerstation.com/forums/archive/index.php/t-34303.html
EDIT -- basically from all I've read, with the stock PCM, it's a direct bolt on with the exception of a few sensors (VSS and DTR sensors on the 5r) won't be used. And you'd want to get a new EPC solenoid due to pressure differences.
Goodluck! :thumbsup:
Sweet. Thanks for the quick reply.
As far as the bell housing. It will have all the holes +1 extra that wont be used. The 5r has 9 holes but only 8 are used. No mods needed.
