4R55E transmission to ford explorer 1995 year 4*4 | Ford Explorer Forums - Serious Explorations
Lviv
95 Limited
4R55E transmission drive forward in Neutral and don't move in reverse
hello, i has bought in USA rebuild 4R55E transmission to ford explorer 1995 year 4*4 . This transmission installed to truck only few days ago. truck start great and drive perfect. but after 20 miles, troubles started. he runs forward in all transmission gear selectors (in N and P i see engine loaded), in R one second drive forward and stopped (when R on). in N drive to front very strong. if i need go back, i must stopped engine and pushed truck to rear. i removed oil pan and remove valve body. all see great, no damage and oil clear. i check manual valve and all solenoids. all good. i start engine to few seconds w/o oil in transmission pan, and he dont run. i think forward clutch not jammed. when i add oil in transmission and start engine, aprox 10 seconds truck not moved in engine idling speed. i try give more acceleration and he start moved after few second he start moved in N he began to go very strongly (after i has released a brake.) i shut off engine and go. I return to garage today morning and start engine in N selector. when engine only started, truck go forward so strong (no paused). Guys, please help me. should me advise where review. That it can be. Any ideas about this problem? i live in Ukraine, sorry for my english. i want repair it local. i don't know ford RWD transmission good. to this moment i rebuild only two chrysler FWD transmission. I WAITING YOUR ANSWER>
thanks, Roman
hello,
morning i returned to checking transmission. I removed oil pan (now i not waiting more time) i start engine in N transmission selector. Car start moved w/o oil pan. i shut off engine, and faster unbolted valve body (oil not have time to leak from converter.) i start engine and car start moved, but more oils go from converter and he moved slow. Now i think, the front clutch pack died. when more oil leak from converter, car don't want moved. i think today i start removed transmission from car.
thanks, Roman
