Mountinheer
- August 6, 2016
- 2001 Mercury Mountaineer
+1 on trans jack...
I thought of replacing the gasket too, but fluid should not be leaking into the space between the cases in the first place... right?
I read somewhere that someone's trans leaked into T-case and they had no idea because the gasket was good. Until the rear seal blew off the t-case...
Biggest problem with removing t-case is you have to rotate it 90 degrees to get it on/off. Think I will build a jig to support it and allow it to rotate.
Thanks for the help!
