4R70W Transmission--HELP! | Ford Explorer Forums
Nightbiker07
02 Ranger
Ok, so I stuffed a 5.0 into my Ranger.....
I have been driving it problem free for about 5000 miles, and then something broke.
I am pretty sure it is a valve body/solenoid issue.
Ok, so I parked my truck, came back out 5 minutes later, and no reverse unless its revved up. Then it slams into gear and goes. For about 15 reverses, then it stopped completely, for the most part, once in a while it will catch, but the problem got a lot worse in a hurry..... Forward is similar, and the shifts are VERY soft, but after it engages into gear, it stays and doesnt slip-but before it engages, it slips REAL bad.....I limped it to our shop.
When I parked the truck, it was perfectly fine. So something happened while it was parked. I have done some reading, and it seems like it suddenly starting like that after parking the vehicle isnt too uncommon. But I havent been able to stumble into any resolutions.
I came back out a day later and went to move the truck, and it drove just fine until the trans warmed up, then it went back to the same issues. After it engages, it will stay perfectly engaged in lower RPMs, until you hit 1500 RPM or so (right about when it would disengage so you can stop), then it falls out of gear. Doesnt seem to slip as its going down the road, but taking off from the light is bad news, it feels like its slipping terribly until it slams into gear.
The warmer the trans gets, the worse the problem gets. it gets to the point where it slips like hell, then will grab into gear, then slip back out, back in. back out, and just behave very erratically and slip real bad until it actually engages for good. (in not driving the truck anymore, I dont want to burn the clutches out or break any hard parts)
A few other bits of information:.
When I installed the trans, I had to replace the pump in the front of the trans, the shaft was snapped. Its been driving just fine for about 5000 miles, but I was curious if maybe something let loose in there and is creating the problem,
One final note, the truck has a PCM tune. The shifts have been firmed up via the tune, not sure of that could have maybe caused a solenoid/seal failure. But, the problem arose after I parked it, not while I was driving it.
I am thinking and hoping it is the main pressure regulator, they are known to be a weak link in these transmissions, and it would make sense because EVERYTHING stopped working right so suddenly.
I also read this:
Your solenoid reg valve is sticking in the bore when it gets hot. The vehicle will work fine cold as the valve is in the relaxed position. Once a set of shifts has been made and the valve is stroked, it will seize in the bore. This is because the slight wear in the bore, swelling from heat, and the balance pressure cause just enough resistance to overcome the spring. This is why it clunks coming out of 4th (reg pressure is incorrect). The bigger issue is that the pressure on the solenoid b circuit will build and stroke the 2-3 shift valve ever so slightly. Since 3rd requires the forward clutch to disengage, the forward clutch pressure is bled off on the other side of this valve... resulting in a neutral at a stop that will slam into gear repeatedly. Sonnax offers a resizing kit and an upgraded valve to correct the problem. or you could try another valve body. Careful not to mix early and late designs due to an epc tcc balance hole in the plate, and a regulated plunger under it in the tcc valve.
Installing a line pressure gauge would help determine where the problem is.
I will try to get access to one. I know some people that may have one. Where would I attach it? Surely the trans cooler lines don't carry any kind of pressure
The code I am getting
P0741
Torque converter clutch TCC solenoid ckt perf or stuck off
That code wont cause it to do what it is doing, but there is a problem with the converter clutch system.
