Ddudley84
Dudley
- April 14, 2017
- Gardner ma
- 02 explorer xlt
I have a 02 xlt w 4.0 and 4 wheel drive. Ok so I have been having a bunch of problems with my truck to start a month ago my door switch killed my battery. when I got it started aghen the transmission would shift but it wouldn't move the truck. my 4x4 low light was on I held it and it engaged then it moved but it was clunkie from the four wheel drive not engaging right. Then next time I started it their was no four wheel drive lights on the dash and what seemed no power to the switch so I check all fuses I am good. I went under and looked some one replaced the solinde on the back of my transfer case they didn't wire it right so I soldered it and used heat shrink. Then I started the truck aghen and ther was power to the switch but it didn't seem right. I shut it off restarted it and now it seems there is no power to the four wheel drive aghen. So now I am not sure if it's that solinde some one replaced or the four wheel drive control module. Any ideas please I need help
