in neutral, sitting still, with your foot on the brake, press and hold the low range button and see what happens.
remember you can only shift in and out of low range while sitting still, in neutral with your foot on the brake.
a flashing light means error (probably because the above procedure was not fallowed) if you are doing it correctly, then it could be the shift motor needs to be cleaned (there are threads on that)
