Explodedford
- June 20, 2012
- NEW YORK
- 96 EB
Just swapped a 5.0 motor and trans into my 96 Eddie I have a couple issues with it though
The bw4406 is out of a 97 expedition and the stock speed sensor that was on it got broken off during transportation. So now I don't know if I should order a new speed sensor for a 97 expedition or see if the stock v8 or v6 sensor would work?
My 4wd doesn't seem to work, the front dive shaft spins when engaged in 4wd but the front tires do not. I checked the vacuum lines to the axel disconnect and everything seems to still be hooked up, maybe I'm missing somthing any ideas?
My power steering feels air bound, it's verry choppy. Does anyone know the proper procedure to bleed the system?
