- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
NEW SCAT STROKER CAST STEEL CRANKSHAFT
NEW I BEAM STEEL CONNECTING RODS AND 190,000 PSI ARP BOLTS
HYPEREUTECTIC PISTONS 9.75 TO 1 COMPRESSION
3 PIECE STEEL ROLLER STYLE TIMING CHAIN
ROLLER H.O AWESOME TORQUER CAMSHAFT
HIGH VOLUME OIL PUMP AND SCREEN
NEW WORLD CAST IRON CYLINDER HEADS 64 CC COMBUSTION CHAMBERS
ROLLER TIP ROCKERS
NEW HEAVY DUTY BLACK OXIDE PUSH RODS
NEW REAR SUMP OIL PAN, ALUMINUM TIMING COVER
EDELBROCK PERFORMER RPM DUAL PLANE INTAKE MANIFOLD
NEW 750 CFM EDELBROCK CARBURETOR & ELECT. CHOKE ASSY.
HIGH VOLTAGE ELECTRONIC DISTRIBUTOR
NEW CHAMPION SPARK PLUGS AND 8 MM WIRES
NEW CHROME THERMOSTAT HOUSING
NEW FUEL AND WATER PUMP
NEW DIPSTICK AND TUBE
NEW EDELBROCK AIR CLEANER AND PCV SYSTEM
NEW FUEL LINES AND GAS FILTER
IGNITION TIMING AND CARBURETOR FULLY ADJUSTED
Look at these parts left from your crate engine list. All of those are either lesser or unnecessary parts compared with my 347 engine plans. Add the cost of those, and that is a lot of waste for an engine going into an Explorer.
Others here have said it well, the factory PCM, fuel injection etc. is far superior to any older engine management. We can do anything that the 86-95 Mustang guys do, without about $2000 of add on aftermarket parts. It only requires the proper PCM programming of these 95+ systems to control any engine combination.
I agree, find a donor truck of 96 or 97 years, the under hood wiring harnesses changed a bunch in 1998, plus 1998 has PATS and other big changes. With the complete set of stock donor parts(outside of the engine), you can put together almost any 302, and it can run fine(with PCM tuning). Contact James about that, he is a great source of advice on the process.
My 347 I have in the works has better crank, rods, pistons, heads, intake, timing chain, rockers, and pushrods, than that crate engine listed above. I'll have near $4500 in the total engine, more than I had originally planned. But it will take 10psi or more depending on compression. That crate engine above with the cheap pistons can't handle 10psi reliably.
You should work backwards from the budget, that it a great first step. Knowing what you have to spend, reduce that by tuning costs, donor costs, and trans build costs. Then you will have a much smaller figure, and that is still leaving out some things. Think through your goals carefully, and work hard on the support costs, those will be as much as the engine alone. Regards,
