Some info....
Price.. So Far
Motor & Shipping $1600
306 CI, freshly built plus a few extras thrown in for the conversion. Double hump Oil Pan,All Accessories mounts,Hi Flow water pump, etc.
Tranny $1300
Rebuilt No Core charge Over the counter. Included a Torque Converter and the linkage to fit a late Model V8 explorer for shifting.
Advanced Adapters $575
I got the 50-8404 9" adapter. This includes the new outut shaft so the T-fer case will fit. Should put the Transfer Case about 1" maybe 1/12" longer than stock. My drive shaft was very close to being to short after the 5.5" lift so I may not need a new back shaft. The front one may be in trouble....
This is some of the info from my orginal thread over 13 months ago. I went to
http://www.phoenixtrans.com/ and ordere the AOD from them. I had Advance Adapters send the adapter kit striaght to them and they sent me the tranny complete. Not sure what year it is, can't remember. The tranny shop can help you.
Advice **** Here's what I've learned over the year on doing my own conversion. I think if I had it all to do over again, I would by a complete Donor vehicle. 87 to 93 stangs with high milage can be found for less than 1K. V8 Explorers run closer to 3K. You get all the misc. stuff and brackets this way. The A/A adapter should bolt upto the donor tranny ( check with A/A first ) so your t-case should work. The things that have killed me so far are the small brackets and bolts.
Good Luck with your conversion. My should be running in a few weeks.
