- June 16, 2003
- Humboldt, KS
- 2000 Mounty
Observed issue. According to scangauge, Coolant temp climbs to at least 202 from cold start. Once 202, sometimes as high as 206 is achieved, temp falls to 181, then climbs back to 200, them 181, then around 198, then down to 186, and so on.
It never truly settles in until cruising at highway speed, then not quite settled 197 down to 191
Brings up several things to consider.
The ECT is quite a distance from the thermostat.
The flow across ECT varies, depending on whether heater core valve is open, or closed. The small coolant lines to upper intake from crossover tube allow some flow, just not as much as full heat.
Scangauge data is what the ECT sees. Thermostat sees entirely different coolant.
Maybe I'm overthinking, but this is my observation after 3 different motorcraft dealer purchased thermostats. 3 different radiators, 3 water pumps, 2 engines, and several multi thousand mile mountain trips.
It just bugs me. I want my expensive 193 degree thermostat to show me 193 degrees. Is that asking too much?
