- July 13, 2005
- Location
- NC
- Garner, NC
- 2019 F150
- Callsign
- N1LVN
Fan is off. For anyone reading I would *not* suggest trying to remove the pulley by removing the bolts. All it does is remove the pulley cover, and then after you drop the bolts about 100 times, you have to tighten them back up .... and FINALLY find an place with the loaner tool. Thanks to the little old lady at PepBoys, I have a set of every fan clutch wrenche a person could ever want, for 10 days.
For posterity, here is how I finally got the screws loose on the pulley ... only to have to put them back on. Strap wrench on the pulley, 13mm wratcheting wrench on the bolts, and bars on both:
Well, I thought I was good to go once the fan was off. Not so much. The strap wrench just bends when I try to hold the harmonic balancer with it. Off to Sears tomorrow to get a metal strap wrench, unless someone has a better idea. I ended up pulling off the lower pulley, and the tensioner to I had more room to work, and that will help, if I can get a strap wrench that doesn't just bend like rubber.
