RangerDude100
- January 18, 2012
Hi, this message is more directed at Glacier but if anyone else can help let me know.
I have a 1999 4.0 ranger with a 5R55E, I had to replace the valve body gaskets due to a valve body leak (corner blown off, when transmission was cold I would have to wait for Drive to work). While I was in there I installed the Transgo Shift Kit. I only installed the valve body parts, not the pump parts (valve body torqued twice to 95 inch lbs). I also changed the EPC solenoid. I really never paid much attention on how this truck shifted ahead of time but now I notice the 3-4 shift is sloppy, no flaring, it just takes about a second or two to shift and it is gradual (rpm does not jump down like the other gears). All other gears are snappy, even the 4-5 shift is snappy. The intermediate band was originally adjusted for 120 inch lbs then backed off 2 turns. After reading other posts I went back and adjusted it again, this time 1.5 turns back. I did no adjust it as the Transgo instructions said as I felt this would have been to tight. Forgot to add, the mileage on vehicle is low, around 80K miles. Temperature does not affect this issue.
Thanks
Thanks
