Dweano
- October 3, 2012
- 1996 ford Ranger
First off...New member here. Hello!
Second, disclaimer...I have a Ranger, not an Explorer
Third, I mostly hang out on therangerstation and Ranger-forums
Fourth...down to business. I had a 4R55E with 190,000 then put big old 33's Toyo Open Country's on it (heavy!) with 3.73 gears. I finally regeared to 4.56s but the damage was done...and one day it blew up.
So I am going to put in a 5R55E in it. I have a used one with 130,000kms (not low, but I got it for cheap and it should be in good shape, it was out of an Explorer)
Currently my Ranger is down to only an engine, tranny is out and everything. Before I put the 5R55E in I am just wondering what I should do to pimp out this tranny and make sure that I have a long lasting tranny (no I am not going to swap in a manual, too much work )
1st question: is there things I should replace while it is out/while things are getting taken apart? Main seal? Torque Converter seal? Etc?
2nd: After market stuff...what is worth getting? I eventually wanna get a CVB valve body (best I heard...worth it? What does it do?...anything else? Shift kits? My old transmission used to take awhile to engage. Like two seconds from putting the level into drive or reverse before it would engage...is there something that can fix that?
3rd: Check this out: http://sporttracclub.21.forumer.com/viewtopic.php?t=989
3A: Basically adding in an external cooler and a oil filter in line to get a better amount of filtration and cooling? My lines and heat exchanger thing is probably not squeeky clean...and it sounds worth doing? where should I get parts?
3B: The thermostat bypass sounds good to me but I do not understand it? Haha
4: What all should I do while it is out? I am going to extend the breather tube I believe and hopefully do the cooler and new lines and oil filter...add a magnetic drain plug?
I am sure I will have more questions as I am in the middle of the project. I haven't been getting any help from other places then I found this place and I was like Wowie so much transmission knowledge!! Hopefully you guys can help
Dweano
Dweano
