ThatGuyJohn
- July 16, 2012
- 1997 Ford Explorer
Vehicle: 1997 Ford Explorer 2WD
Motor: 4.0 V6 SOHC
Trans: 5r55e
Vehicle purchased for $900, with known transmission "issues".
I was getting the 2-3 shift flare horribly and it will not go into final gear at all, except on 2 or three occasions under heavy acceleration. I think it finally took the big dump. Now it will go about 300 yards before I have to shut her down and let her sit about an hour before I can go another 300 yards. So now it just sits. I don't want to chance damaging the motor, it runs so smooth and feels like it has plenty of life left in it.
Here is what I have done and have into it so far.
So far I racked up a $129 Trans Shop bill. (Towing and so called Diagnostic)
Was able to drive it home from the shop after telling me it needed a new trans.
$30 approx. for filter and valve body gaskets.
Dropped the pan, had quite a bit of metallic speckles in the pan and the magnet was loaded with it as well. Fluid.. burnt to hell.
Dropped the Valve body and of course on top of the separator plate there was a good bit of metallic speckles on top of it. Once I got the separator plate off I found that there was a good bit of metallic speckles in the passage ways along with one section in particular that was "packed with" what I would call metallic shavings. I cleaned all of it out being extremely careful not to lose, misplace or damage anything.
It was during the cleaning process I happen to notice that the mounting bracket for the TCC solenoid was broken. How I didn't notice while taking the VB down.. I don't know.
It was way late at night.. or way early in the morning when I decided to button it all back up to take a few days to decide what to do.
Do I keep picking at it changing parts as I find them broken or trying to use the process of elimination. I have been told that the "shavings" are likely from the bands. So I would end up trying to change those as well.
Another option:
I have found a Pick-N-Pull sort of close by where I can pull a transmission for $125 / approx. $150 with torque converter. Or I can pull solenoids at $20 a pop. Or pull a complete VB for $75. All with the chance of swapping parts and have money and time wasted, if I were even able to find the trans to pull or pull parts from, and still end up with a bad trans.
[Adding To] Also, they have a dollar a day warranty. Where I can pay for a warranty upfront and bring back to swap, but no cash back only credit. So for 30 bucks I get a month the see if the trans is any good and so on.
So the final question:
To replace or keep picking at it?
I am sort of leaning towards just replacing it, but at the same time it would give me a few more gray hairs if I did the swap and ended up with a bad trans.
If there is a chance I can get her road worthy again for under $300 plus a set of tires and other random suspension and steering components over the next few months, I think this could be one of those vehicles I would keep for years, til the wheels fall off!
[Thanks]
I wanted to add to and go ahead and thank Glacier and Brooklyn for all of their helpful instructions on this particular Transmission. I've done quite a few swaps, but never had the confidence to crack the bottom end of a trans open until I read their posts.
So Thank You Brooklyn & Glacier
Motor: 4.0 V6 SOHC
Trans: 5r55e
Another option:
[Thanks]
