Charlie Daniel
- November 18, 2018
- Location
- Georgia
- AUGUSTA, GA
- 1999 Ford explorer sport
I have read several threads on no reverse and found a lot of good ideas. All my gears work fine except reverse. At the beginning it was slow going into reverse and then nothing. I removed the value body and found a broken gasket near the reverse servo. The reverse servo fell out when I removed the plate. I couldn't see up in there very far, so I took a Phillips screw driver and I could fill the spring tension of the band. I put the servo piston back in but I could not feel any tension like up against the band. It seems to bottom out without touching anything. Does anyone know if that means the tab on the band is broken. After replacing the gaskets and tighten to specs and filling with oil, I still had no reverse. Any ideas out there. Thanks
