rocket 5979
Resident Gearhead
- April 22, 2002
- Lake Villa, Illinois
- '03 XLT 4.6
Rob, I'm surprised that you forgot the best 5R available so far, the Aviator 5R55.
I read elsewhere(Todd maybe) that there is a difference in how the N model achieves 2nd and 3rd gear, synchronized versus non synchronized. That is part of the strength inherent in the AOD's(4R70W), using a band versus clutches for certain gear changes etc.
I didn't mention the Avi tranny because I don't have any personal experience with them.
Yes, the nonsynchronous way of shifting versus synchronous helps eliminate any possibility of RPM flare between shifts. One is "gripping one and then letting go of the other" at the same time. The other "lets go and then grips" very shortly after which requires better choreography. That is usually fine and dandy until the PCM gets confused on occasion. If you are hard on the gas then there will be a flare in the RPM's and then the trans will lock into gear in a jolting manner.
The internals in the 4R70W & 4R75W are beefier than those in the 5R series trannies too when in stock form.
