5R55W Transmission Dipstick Information. | Ford Explorer Forums
jesse lopez
HOLLYWOOD
2005 XLT
Hello Forum,
The 5R55W transmission does not use the typical dipstick for checking fluid. Instead they figured that crawling under the truck to check the fluid with tools is probably a much better method. Start the truck,crawl underneath, and locate the smaller bolt on the pan. Usually a bigger bolt with a SMALLER BOLT IN THE CENTER OF THE BIG ONE. Remove the smaller center bolt. If fluid doesn't drip steadly, then its low on fluid.
Hope this helps.
Jesse:eek::eek::eek:
