Why would someone even consider mounting rims that do not have the proper lug pattern?
The larger bolt circle will force your lugs to bend outward and or deform the conical seat in the rim, both increasing the chance of a failure.
If you don’t value your own personal safety, at least consider others around you if you should loose control of your vehicle at highway speeds because you saved a few bucks on the wrong rims.
