8.8 spool | Ford Explorer Forums
8.8 spool
bluethunder
Raleigh, NC
1996 XLT
does anybody make a spool for the 8.8? thanks
-jonathan
yup....a few places make it...auburn makes one, and so does moser. check out their web sites for more info....they also make mini spools which go inside an open diffy case....
good luck
it is a comon peice because the mustangs have 8.8 you should not have any problems finding one.
that is true, however you need to remember that the mustang is a 28 spline axle shaft, where the explorer has a 31 spline....if you get a part for a 28 spline, it won't work with the exploder
i think that most of the mustang guys would have upgraded to 31 spline first. the 31 unit that comes in the explorers where first used in mustang aplication any ways. dont worry you will be able to find a lot of companies that have them.
Another question on the same topic. Can you still run c-clips with a spool or do you need a c-clip eliminator kit?
