Bronco2inWNC
- June 10, 2009
- Asheville, NC
- 88 Bronco 2
Alright, I have a 88 Bronco 2, 2.9L V-6, 5-speed and 4wd. first a lil backround info. My starter has been acting up for a while. And by acting up i mean not turning the flywheel. So not having any money to buy a new starter led me to tap on the starter housing with a small hammer. Only had to do this occasionally and once I gave the starter a cpl of sharp raps it turned over. So one day I jump in the bronco and it decides it aint going to start so I do my little rapping deal and tryed again. Still no start so I rolled it off and got it somewhere where I could work on it. So I take the starter off and head over to Advance Auto Parts to get a remanufactured starter. I get the "new" starter home and back into the Bronco and now when I turn the key I get a grinding sound. I figure maybe it was the starter so took it back and paid the difference for a NEW starter. Put that one in and get the same grinding noise then wat sounds like the starter free spinning. I pulled the starter back off and got to looking at the gear on the starter and it looks like the starter is only going in about half the way. Meaning only half of the teeth on the starter's gear is making contact with the flywheel.
Now I have read a few of the starting problems posts and I am going to go out and check the solenoid and see if its bad. I have already looked over the flywheel and it looks alright. I even took the time to count the teeth on the flywheel. I know that I have 138 teeth on the flywheel. If anyone cud help me out and lend some advice on this matter it would be greatly appreciated. Also if someone knows how many teeth the Stock Original FlyWheel had and cud post that I appreciate it.
