lofton316
- April 29, 2006
- Jersey
- 1991 Ford Explorer
91 exp fuel pump hooked up wrong?Almost Fixed!
I had two fuel pumps installed last year, since then there has been a slow start in the morning, have to crank the engines a few times to get it started, could take up to 10 minutes doing it, but if it turn the ignition on and off real quick i could get it to start in less then 3 seconds. Now i was wondering if my fuel pump is could have something to do with it, the red wire from the pump i guess is hooked up directed to the fuse pump under the steering wheel. The red wire is wrapped around a yellow fuse 20 i think, when i take it out the fuel pump doesnt come on. Could this be cause my slow start in the morning, once is ran for a while it will start right up for a few hours. Then once i let it sit the same problem, all started after the fuel pump was changed. starter silionoid has been changed.ignition switch has been changed but not the key part.
Edit
here are the pics
here are the pics
this is where the red wire is
and this is where it goes
Edit
here are the pics
here are the pics
