92 Explorer 5spd Transmission Leaking From Top | Ford Explorer Forums
ghosty
Edmonton
92 Ford Explorer XL 5spd
My 92 5spd explorer's transmission has been leaking from the top. I know there is a rubber seal between the transmission and the control housing was wondering if the could be it or something else along the top?
There are rubber plugs in the top cover for the shift rails. The plugs dry out and leak. They can be replaced with small freeze plugs for a permanent fix.
Do you know if I can get away without the dana or dorman parts? For example if I used a different brand same size? The dana and dorman parts are unavailable in my region
The brand doesn't matter, just the size.
