antogt
- January 18, 2004
- MICHIGAN
- '92 xlt 4x4 & '91 EB 2wd.
'92 Wont Shift out of 1st or 2nd.... Ive tried everything!
Ive taken this as far I can. Now im stumped. It started out where the ex would just hang out to long in 1st and 2nd, then it went to over-reving in all the gears. I did everything I learned from this site. New Vac mod, replaced govenor, dropped valve body checked for stuck valves, tightened valve body bolts to spec, new filter and gasket, repaired a large breach in the vac line to the vac mod. And now after all that, it wont shift out of 1st or 2nd unless I feather the throttle at the the top of the gear. All the other gears are now fine. Od is fine , im pretty sure the tc is doing what it is supposed to. It down shifts fine. My ex is 92 xlt 4wd, w/ a a4ld. The 3/4 solonoid is a replacement with no screen btw. Is it possible a valve is stuck in the valve body and i just missed it?? If anyone has any suggestions I could really use the help. Thanks.
