'93 4.0L , Fuel rail to Lower intake gasket | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
sunrse777
New York
'91 XLT Supercab 4X4
How difficult is it to change this gasket ?? I have the lower intake off the engine with the fuel rail still attached to it.. How hard is it to remove and replace this gasket ?? Thanks.. :rangerred:
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
sunrse777
New York
Has anyone taken the fuel rail off the lower intake ?? I am changing the heads on my 4.0L and I have the intake off. Just wondering how difficult it is to line up the injectors and the gasket if I take the fuel rail off...... Thanks..
pauley
Madison, Wisconsin
93 xlt
it will be fine its not that hard use some Vaseline on the o rings that will help them go back into the intake.
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
I believe you need a reverse torx for two of the bolts holding the sandwich together. No positive... When I replaced injectors on a friends '93 I needed this reverse torx socket
http://www.thetoolwarehouse.net/p-3049-lisle-26750.aspx
Not hard to line up angle the Rail so the rear injectors line up and work your way forward.
sunrse777
New York
Thanks Tony H !! That pointer of lining up the rear injectors by tilting the manifold is a good one .... BTW,,, you do need a torx socket to tighten the studs that attach the fuel rail to the lower intake ... not sure of the size, but it is a small one...
tootall_54
Worthington,IN
92' XLT
does anyone know how to completely remover a fuel rail off a 93 explorer xlt because i am looking to make it into a spcer for my 92 xlt
