Fuel Injectors
If you have the time and money you can send the injectors out to be cleaned and tested, otherwise you should at least use an ohm meter and check the resistance of each, it should be somewhere between 13.5 - 19 ohms. Always replace the O-Rings they get dry and hard. The new ones go together easier and won't leak. Use light weight oil to lubriccate them, no silicone. Clean everything and check the lower intake manifold for pitting arround the water ports. Install the lower intake gasket properly with RTV sealant. You have to put a bead of sealant on the four corners of the engine block where the manifold joins the block. Haynes recommends RTV arroud the water ports and the front sealing surface as well. Position the gasket over the alignment studs on the block and put a bead of RTV on the gasket at the four corners. Install the LIM over the alignment studs. My car didn't have the studs it only had bolts, I purchase threaded rod with the same thread and cut them down to align the LIM, make sure they are long enough so you can remove them.Dry fit the LIM a few times before you do the final install, its not so easy to position. Install the bolts and torque them in the correct sequence in three steps. The 95 and earlier 4.0 is 72 in.lbs/ 144 in. lbs/192 in. lbs.
Replace all gaskets as you go. I put the injectors in rail first. Torque everthig in the right sequence and specification. Clean all bolts and threaded holes to get proper torque and tightenig sequence pattern is critical. Have fun they are great cars to work on.
