Watchman
- November 11, 2013
- Virginia
- 1993 Explorer Sport-4WD
Yesterday, noticed coolant bottle was empty and level was down in radiator - I topped it off while running. I then drove it about a mile and the temp gauge almost pegged. Then it went to the normal range about 10 o clock position. I turned around and came back and parked it and heard the bottle bubbling over. This morning the bottle was empty. I topped it off again after starting it. The same issue above repeated itself.
So, here are the symptoms: 1. Upper radiator hose is hot, lower is not. 2. After temp gauge is in normal - turned on heater and fan and air is cool - not even warm. 3. White smoke coming from exhaust - but stops after driving a while.
Any suggestions ?
Any suggestions ?
