Lafferty
- June 2, 2012
- Rhode Island
- '93 Explorer
Hey guys, I have a 93 Explorer with malfunctioning headlights. The previous owner had plug and play hids installed. Not much info on those. I replaced them wi tt h the stock lights since the hids did not have a hi-beam feature. Well when the lights are turned on the hi-beam dash indicator light is permanently on. When I turn on the hi-beams the headlights dim. The flash feature on the multi function switch does nothing to the brightness of the headlights. I do not want to pay for a new multi function switch from a parts store. If I have to pull the switch and repair it I will. Is there anything else that could be causing this issue? My truck does not have auto lamps. The only control for the headlights on the dash left of the steering wheel.
