93 explorer PCM issues | Ford Explorer Forums
Bboy
Utah
1999 Ford Ranger xlt 5.0
Question for you explorer experts. I put everything out of a 93 explorer sport (don't worry I have cool plans for the sport) into my bronco ii(engine, 5 speed, dash and harness) and before I pulled it I found out my explorer's PCM was bad, my buddy has a few 91 computers that I've tried in it but it causes it to surge between 2000-3000 rpms. Just trying to figure it out, I know that the 91 explorers only have 1 O2 sensor but mine has 2 so I'm wondering if 93 is the only year I can use since I also don't have a EGR. Also I tried soldering new capacitors into my original computer and checked continuity but it still doesn't run good (super sluggish, no power, throttle lag). Also wondering if there's a way to check that my "original" computer is the correct on for this harness/engine
I have 4 computers
Original computer code: F37F-12A650-YB. ANY1
91 Navajo computer code (runs best with this but still surge's):
F27F-12A650-TC X2X2
Other 2 91 explorer Computers: F07F-12A650-VA. EOL
You need a 93 PCM
93 has two 02 sensor
No cam synchro and no egr
94 pcm has a cam sensor and egr
So you need a 93 pcm for it to run correctly
Your factory 93 pcm was the ANY1 code? I may have one of these
You need a 93 PCM
Ok that's what I was kind of wondering. I was reading that one from a ranger might work? And yes mine was the ANY1 code so if you have one we might be able to work something out.
Yes 93 ranger is same pcm as long as it was a 93 no egr no cam synchro and same transmission
Explorer Explorer sport ranger and Navajo all same pcm
I will check for a any1 in my collection today
Were you able to check if you have one?
Dang I forgot got sidetracked
Will check this afternoon
I have two totes full of old pcm up on a high shelf will get them down today and have a look
