Birdman1
- May 1, 2006
- Reno NV
- 94 Explorer Sport 5 spd
Hi guys,
I have a '94 Explorer 2dr, 5-spd, pretty much stock drivetrain. for a few weeks now it will most days start and run fine, but some days it won't start without giving it gas, then it will idle very low, barely 500rpm. the RPM will randomly (truly random, just once in a while) jump several hundred, then come back down, this is almost dangerous as closely as my wife follows people sometimes. the check engine light has NOT been on at all.
I have cleaned the MAF thoroughly (twice) and cleaned the IAC well. I read up on this site on how to pull codes, so today I had my wife sit and write down numbers as I counted them (KOEO). they looked as follows:
565/565 // 112/215/721/112/215/721/1.
We then went for a 45 minute drive to run some errands, and halfway thru this the CEL came on. stopped at one last store and came out, the CEL was back off.
When we got home, we pulled the codes again. now they look like this:
565/565 // 112/215/721/133/112/215/721/133/2. (looks like it added a 133)
the 565 appears to be the canister purge solenoid (which looks to be a ***** to get to), which makes sense since the truck has randomly had a dead gas smell off and on for a long time. The 215 is something to do with the coil, but the truck does not miss or really act like an ignition problem to me. the 112 says intake air temp sensor, and yes the truck was fully up to temp (although I do have a 160 T-stat in it, but it has been there for 2 years now with no problems).
My questions:
can any of these make it run this weirdly?
what the hell are 721 and 133, they are not on the lists I have found here.
what does the single number at the end mean?
So, I am going to unhook the battery for a bit, hook it back up, have the wife drive it for a couple of days, then pull the codes again, and report back.
I am stubborn about running out and buying various things until I have even a half-assed clue what is going on.
I appreciate any and all help you Explorer guru's can give me.
My questions:
