Softballdad
- July 16, 2012
- Sandy, OR
- 2000 Explorer
Hi all, I'm new to posting. Have been looking for some help. My 94 Explorer is having issues. It started bogging down on hills but was fine on the flats. Then that progressed into chugging from a stop until about 20mph at which point seemed to smooth out. I recently changed the fuel filter and it seemed to be a lot better in acceleration. Friday night it almost stalled out on me while I was at a stop light. I thought it might be getting overheated as my gauge was above where it normally is. Finally got through traffic and once I was moving again it seemed to smooth out. All the way home that night idle was fine. Yesterday I went to go somewhere and it started again. Turned around and came home. Now I'm not sure where to start. I'm going to go pull the plugs today. I have read many different posts that mimic my symptoms, and there are SO many different things it could be. Fuel pump? Lower intake bolts loose? I already checked the MAF sensor. I checked the battery cables for corrosion and they look fine. It had good response at highway speed, although I generally can't get it over 65mph.
Also, every once in a while it won't start. This could be related. I changed the fuel pump relay and it ran fine for a couple months. Then it happened again. This time I just had to wait it out before it would start. I don't know why, but I couldn't hear the pump turn on when I turned the key. Probably just a loose wire somewhere, but what are the odds that I switch out the relay and it starts just fine? Any help would be great ! Thanks!
I
I
