You said you replaced the pump in your second post?
Whatever the case, we are nowhere near replacing the pump yet... the reason why is that highway driving consumes more fuel than idling, so that doesn't quite make sense. We may end up there anyway, but here's my thing:
Lean condition means not enough fuel or too much air. Fundamental. A fuel pressure reading with the problem occuring allows us reduce the potential problems without replacing parts.
Here is what I want you to do, and again, I am not really chasing a fuel delivery issue, I want to rule it out:
- Buy or borrow a fuel pressure test gauge, such as this one: Amazon.com: Actron CP7818 Fuel Pressure Tester Kit,Black: Automotive you may find one like it cheaper somewhere else, that's fine... stores like O'Reilly's will loan it to you free with a deposit.
- If you have run the engine, then stop and allow it to cool to COLD.
- Connect it to the port. The port looks a LOT like a metal tire stem... you were near it when you changed the pressure regulator, it's on the fuel rail just behind it. You may have some gas spurting/leaking when you do this, so be prepared.
- Turn the key to ON, but do not start. RECORD THE READING
- Repeat step 4, and again, record the reading
- Start the engine and immediately record the readings as it goes from high idle to your rough idle. At least 3 readings for this, please.
- Allow the engine to warm up. If the pressure changes in any way, please describe it.
- As you can, with assistance as needed, open the throttle to 1,000 rpm, then 1,500 rpm and 2,000 rpm. Record the pressure for these 3 conditions.
- Return the engine to idle and record that reading.
- Shut down the engine.
- With the engine off, record the pressure immediately, then after 10 seconds, 30 seconds, 1 minute, 5 minutes, 1 hour and if you can, the pressure remaining overnight.
The ideal readings are 35 PSI at idle, as high as 40 PSI when revving the engine, and pressure maintained overnight.
If you do this and report all the readings in detail, I can rule in/out the fuel system and if there is a problem, I can most likely give you fairly precise troubleshooting.
For example, if your idle pressure is lower than 35 PSI, I'm going to be thinking about the fuel filter, then the pump.
If the pressure does not rise when revving, I'm going to be thinking about the pressure regulator.
If the pressure drops off after shutting down, I'm going to be thinking about the fuel pump or the injectors.
This is a lot of work, but it will conclusively rule in/out and the time will be well invested.
I imagine there are many videos online on fuel pressure testing, so you might want to look at a few of those.
I would also like you to remove that plastic tube between the MAF and the throttle and inspect it carefully for any cracks that might open up if it is flexed. This is a classic cause and I would like to rule that in/out.
If you find yourself with more time, I'd like you to test the MAF as per this website:
Part 1 -How to Test the Ford Mass Air Flow (MAF) Sensor
I think if you do all these things and report readings and results... please... I spent a lot of time thinking and typing this out. Please do not tell me: The pressure is fine. Please give me the details I am asking for. Ok, I'll check back later this weekend, good luck!
