'94 Limited fog lights on a '91 sport... | Ford Explorer Forums - Serious Explorations
I was given the front valance and fog lamp brackets from a '94 Limited Sport...I cannot find any replacement haousings for the lights!
Is this only available as an assembly?
Does anyone have a suggestion or...a set of lamp housings?
found what I need...
I appreciate the input and suggestions...I am looking specifically for the front valance mtd. Bosch lights...I found them in Canada and the have the clam shell mount on the back for proper adjustment.
I have the brackets and the valance that will bolt to the frame and the bumper for a steady ride for the lights...
Where did you find them??
I ended up buying them on amazon.com.
Do a search on amazon.com for "bosch scout fog lamps"
Their part number is 0305555901. It is just for the light kit it IS NOT
for the brackets.
If you want the oem brackets you need to find a donor Exp.front valance that had the lights in it and get the bracket off a donor.
The bracket bolts up to the frame and thew only thing you need is longer bolot yo go thru the bracket.
I prefer this method of mounting rather then on the bumper its much more stable.
Try toget the from Ford...$$$$$
