Jameszar
- November 13, 2009
- Mission B.C.
- '94 XLT
First off, thank you Blacksheep Josh for the list of codes and their meanings, very helpful. I used the wire bridge trick and sat in my explorer for about a half hour making dashes on paper.This is what she told me.
335 O EGR Sensor voltage out-of-range
171 C Heated Oxygen sensor unable to switch, right side
172 R,C Heated Oxygen sensor indicates lean condition, right side
175 C Heated oxygen sensor unable to switch, left side
176 C Heated oxygen sensor indicates lean condition, left side
181 C Adaptive Fuel rich limit reached at part throttle, right side
186 C Injector Pulse-width higher than expected
189 C Adaptive Fuel rich limit reached, left side
332 C,R EGR valve opening not detected.
Okay, so first and last are EGR one for the sensor one for the valve and a bunch of stuff that (I'm no mechanic) could maybe caused by mister EGR valve failing? Options, opinions? I'm a carpenter not a mechanic lol.
