huntman58
- February 13, 2007
- Fremont calif.
- 2013 Dodge Advenger
I have a 94 xlt with some big problems that I am going to try and fix for my nephew over the next few months.
The back ground as I know it.
He was given the truck after it had sat for a few years. They replaced the intake gaskets then. This was about 3 years ago now. The truck only has about 160,000 miles on it.
The motor ran great for a few years then about 2 months ago he over heated it. now it runs realy bad with a massive miss and loss of power. looks to be blowing white smoke (steam?) out the back end . Dip stick for the oil shows way over filled and the radiator is dry also very very rusty.
PVC valve shows brown creamy film on the bottom
Lots of oil in the intake to be the sensors are covered in a wet oil coating that drips.
So our plan is top end we rebuild it. bottom end damage its junk yard city for it as I can not pull the whole motor and rebuild it because of my disability and he can not help as he is a long haul trucker gone most of the time and well he is not to mechanical and more of a hindrance then help believe me .
So how likely is it for a 4.0 OHV to creak a block? That is my main worry as short of that the bottom end should be sound and after cleaning it out with rebuilding the top end should be able to get it running again as it used to. If not I will be pulling some parts from it that I need and or may need and the rest will go away. It’s a 2x4 by the way
