ScrumDawg
- August 21, 2012
- Nashville, TN
Just purchased and two things are not working at all and one partially.
#1 low beam lamp will not work while high beam is fine. Any suggestions on fixing this myself?
#2 Rear windows will not go down. When button is pushed the dome light dims which tells me there is a power drain. Guy I bought it from said the previous owner had the "switch" disabled to keep the kids from opening them. Does this sound right to you?
#3 The A/C works, for a while and then no longer cools just blows air. Turn it off and wait 30 seconds turn back on to MAX A/C and it is cooling again. Dumped an 18 oz can of R134a and that did not help alleviate the problem. Any help here would be appreciated. Thank you.
