95 X Limited A/C Blows HEAT | Ford Explorer Forums
95FreezeJG
Jax,Florida
95 Explorer Limited
95 Explorer Limited
All of a sudden A/C is blowing heat.
Compressor Clutch engages for a few seconds then clicks off, then a few seconds it clicks on,etc.
I have taken the Blend Door Actuator out, it works, and is aligned in the d shape groove.
All Vacuum lines I can find have been checked
STILL no answer.
While looking I was checking the (valve I don't know what its called) that has two lines running into it, a vacuum piece off the side, and two lines running out of it into and through the firewall. When moving this "valve" it broke off into my hand and coolant(HOT) went everywhere.I don't know what this "valve" is called but I need a new one.
As far as the A/C I don't know what else to try here guys any help would be appreciated. THANKS
Oh,Before any of this happened, the Max A/C would only blow cold on the high setting. The heater worked fine. All of a sudden this happened.
Could be broken blend door?
I check the blend door, and moved it by hand its good to go also the actuator is good.
Now the compressor is not cycling on I checked power to the compressor and it has none. Now my question is if the A/C compressor cycler switch goes bad will it not send power to the compressor or is this a wiring problem somewhere. Before the compressor stopped kicking on it was quick cycling, on for ab out 3 secs, then off for 2 then on for 5 then off for 2
If the pressure switch is bad it will not cycle. Try jumping the wires at the switch momentarily to make sure the compressor starts.
I jumped the hot lead off the compressor connection right next to the pulley to the positive terminal on the battery and the compressor cycles as long as I want to hold it there sooooo???? I'm guessing by it working by jumping it and what your saying is the switch is bad??
