I had the same thing happen, '91 Bauer with only 56k but still had the original plugs and wires .... here's what I did ...
Heat the remains and as best you can ONLY the remains of the spark plug until you get a faint red glow ... then WALK AWAY for half an hour or so and let it COMPLETELY cool off ... then use your easy out on it, mine practically fell out
The key is you have two dissimilar metals, iron and aluminum ... you heat the iron and it expands against the aluminum (which you try not to heat) and when it cools it tends to 'shrink' more than the aluminum ... After I did this I turned mine a quarter trun with the easy out using little force (At least compared to before) and unthreaded it the rest of the way by hand ... and buddy that works all day on lift/fork trucks told me to do this and I was amazed how well it worked, much better than if it were iron on iron .... I found mine wasn't really froze/corroded on the threads but on the collar between threads and the hex nut, why Ford doesn't allow a bit more clearance there I'll never know ....
The problem with American Engineering today is the engineers never have to work on their own designs after they have been in the field a few years ... things would be a LOT different if they did, guaranteed ...
