I'm going to jump in and say check the rust out better--
Body rust usually means poor maintenance-
check the undercarriage well--especially the rear leaf spring shackles-shocks and other components for rust
Be sure to check the stock jack out--look at the area where it sits on the truck for corrosion-
while there--
lower the spare tire and look in the spare tire storage area-
Drive the truck on a quiet lot-
Move in reverse for about 10 feet, the forward, several times listening for a "clunking" under your feet-
Drive it for a few miles. Go to autozone and have the codes pulled--
I'm looking for a p1000 code indicating the pcm has been reset--
also-
switch the key on, notice if the check engine light glows steady, then switches off when the truck is started.
Ok so I just took it for a spin and here is what I found
The bad
- Once I hit 60 mph on the highway the check engine light came on. I went to O Reillys and pulled the code, what it gave me was P0133 O2 sensor circuit slow response (Bank 1 sensor 1)
-Felt like the rotors were slightly warped, which led the brake pedal to kind of rough.
- Rear hatch glass does not open
-underbody of the vehicle is very rusty, but is mostly surface rust.
-There is no spare tire, but the thing above the spare was real rusty.
- Carpet in the back hatch area seems to be oily. I stuck my finger under the carpet by the tie down hook and did not feel any rust but there were small black oily chunks under the carpet.
- Suspension parts all are old and rusty (including shocks)
The good
-Transmission shifted fine when switching between reverse for 10 feet and drive for 10 feet, no clunking
-Suspension took the bumps much better than my 90 s-10 and my girlfriends 02 lifted liberty
-Engine accelerated smoothly and I could not hear any exhaust leaks
-AWD works like a champ on my icy alley way
I went in and talked to the dealer and told him what I found, asked him how flexable on price he was. He said that he would take 2,200 for it. I will likely go take a look at it in a couple days, the vehicle was dirty and it would be nice to look it over when it is clean! I forgot to check the jack storage area for rust, but other than that what else should I look over when I go look at the vehicle again?
