- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Hunt the coolant leak from the top down, most will be wet all the way up to the leaking point. So look carefully around the thermostat housing, which in V6's is very prone to leaking. Look for fluid or wetness on the upper engine parts, start at the front most area and find the highest wet spot, and furthest forward.
If you have a decent leak on the ground, that's easier to find the source than a tiny leak. The fuel pump relay should see power full time. The connectors down in the PDB where it's at should have power to one of the terminals. So test those to find the power source, plus be sure those terminals are all up where they should be, so the relay terminals do fully engage them(they don't move downward).
