Stanleyjd
- September 22, 2007
- Virginia Beach, VA
- 97EBawdV8&96XLT4.04x4
GangsterSinner (9:22:11 PM): hey
Glacier991 (9:19:49 PM): hi
GangsterSinner (9:23:24 PM): how are you?
Glacier991 (9:20:05 PM): I'm good thanks, you ?
GangsterSinner (9:23:38 PM): good
GangsterSinner (9:23:56 PM): if you remember i was putting the 01 tranny in the 97 explorer
Glacier991 (9:20:50 PM): Ah yes.
GangsterSinner (9:24:43 PM): well it seems to work but i have another problem
Glacier991 (9:21:21 PM): ok
GangsterSinner (9:25:14 PM): ok so the tranny is in and it goes foward and reverse but now it drives like **** it wont accelerate pase 1500 rpms and engine sounds like ****. many plugs were fouled up and i did a tune up replaced all plugs and wires same result. the truck wasnt like this before. there is a check engine light my friend will bring home his computer from work to diagnoss it. the friend that helped my said it my be an o2 sensor he noticed one was banged up a little. and yes the computer has been reset. does any one know what this is?
Glacier991 (9:23:27 PM): When you have this type of problem, it is usually either electrical in nature or it can be fuel (usually pressure) related.... Fuel pressure testing would be a good idea, you could have a bad Fuel pressure Regulator (FPR), but getting the code read would be helpful most likely.
Glacier991 (9:24:14 PM): there are a host of problems that might produce this result... so start with what the computer is telling you and work from there. You had a good start replacing plugs etc... the fact so many were fouled makes me "suspect" your FPR.
Glacier991 (9:24:44 PM): But suspicion is a bad way to diagnose when you may have a DTC (code) that is golden in terms of telling you what it is.
GangsterSinner (9:28:59 PM): oh and the o/d light keepsflashing
Glacier991 (9:27:09 PM): that means there is a tranny code stored
