diane
- August 16, 2002
- LA
- 97 XLT
For the past 2 months I have had starting problems. I have a new battery. When I go out in the morning to start the car, the battery turns over but it (the car) just does not start. I try this several times, then wait 30 min. or so and try again. Sometimes it starts. If it doesn't start, I gun it. I know I am not supposed to do that but . . .sometimes it starts. If it doesn't, I get my sons and we jump it. (I am afraid I'll kill the battery by trying so much). It seems to start all the time then.
I have had it in 2 different shops 3 times. It always starts for them. However, some work has been done on it.KOEO system pass. EEC Test-system passed, repaired connectors performed fuel pressure test Pressure at 30 PSI. Inspected all electrical connections and PCM pins. All were fine.Then, replaced fuel pump and PCM relay. Both places checked for stored trouble codes-none stored. Is there something else that should be done.? What other words do I use to explain this problem to the mechanic? They both say they cannot fix it until it actully won't start, but I cannot let it sit in a shop for 5 days waiting. Any suggestions? Thank you
