ALL of this has been discussed hundreds of times. there is a search button at the top right of the page somewhere. you will find gobs of info, you just need to sift through it. you can lift your truck 4-6" for around $200. the torsion twist is free, and people have been known to push 3" out of it with longer bolts even on a 4wd. most people only do 2" because it keeps the CV's in a less strained position. and a 2 or 3 inch body lift will run you a little over 100 bucks from summit. a 91-94 body lift will work for your application. some bolts need to modified, and bumper mounts will need to be fabricated. i have no experience with the ranger body lift. if you really want 9" of lift, look into a SAS. it will net you better results than stacking lifts (tt, superlift, and body). if this is just a street truck that you want to look cool, then just go with a tt, body lift and superlift if you can swing the cash for it. the rcd kit would be even more bling, but it will cost you more, but it actually offroads better.
good luck with whatever you do.
